Fog light mod
dznutts
Worked like a charm!!!!!!! Thanks!!!!!:worship:
CEN2MENTAL95
Banned
Expensive Long Island, NY
why would you do this mod when you can just press the damn fog button? its not like they ONLY work with low beams (like most cars with OEM fogs)...u can turn them on with just parking lights...
withac
withac
Eastern Idaho
Actually it's EXACTLY like they work with only the lows. They go off with the brights, that's the whole point, to get them to stay on with the brights.
withac
withac
Eastern Idaho
Did this mod....works good, but now my drls are not working
I have no clue. The only thing I would suggest trying going back over your work, double check that nothing got grounded out or disconnected. I assume you checked fuses?
missta
Nork, NJ
I did check the fuses...all good...double checked jumper wire and connection...nothings grounding. Drls worked when i 1st did the mod. Went out later in the day
withac
withac
Eastern Idaho
I figured you had but hadda ask.
Don't kniw what to say, coincidence maybe?
I got nothin'.
missta
Nork, NJ
I got nothin'.
I will check the relay in the morning....just thought about that. I did the diode drl mod days ago....maybe the relay shook loose
Corrale
