Brake pedal removal
Mr.Jack
Norway
What about the squeaking sound I got when pressing the brake pedal? (Got no rattling.)
Yukongk
Yukongk
NY
I think that's the brake booster that does that. A while back I sprayed silicone on the rod, and on the bolt that holds the brake on. Noise went away, but was never sure if it was a good idea to spray the rod/booster.
Bomba02
Sweet good write up man! glad you tackled it i know I'veI've seen people ask for a fix for this or how to! The fix has been holding pressure back with your foot lol. This is a must for me! did it solve all rattle?
Yukongk
Yukongk
NY
Rattle is gone. I'll update after I hit some big bumps tomorrow if there is rattle, but just moving the pedal side to side w my hand, it feels firmer and quiet, whereas I could easily replicate the rattle before.
Yukongk
Yukongk
NY
Thanks guys. Ride is so much quieter now. Next project is dropping each door panel and tightening loose bolts. Ride should be as quiet as new after that.
Bomba02
even tho my trucks in ruins right now with a wiring mess and the dash out. I replaced my bushing on my brake pedal as well. Old one was smoked no ends like the new one. I was able to use ratchets with 18 mm socket on the drivers outer side, and a 18mm swivel and 2 inch extension and ratchet to remove. Bolt was on there tight working space. Clip and wiring was not a hassle.
TOOLS I USED AND PARTS REMOVED
OLD BUSHING
NEW BUSHING
I haven't been able to drive it yet, but seems to be tighter still has play in it. I haven't been able to drive it yet but once I do, ill update.
Billy
Atreuce
Hartsville, SC
Mine doesn't make noise.. but I want to swap out the actual pedal for something else. Gonna assume that's easy.. but great writeup anyway just incase it does start I know what to do! :D
Richard A
