Obd2 scanner can't read data stream
secfogecko
JBER, AK
The fuse is under the hood, there should be a group of them in a triangle on the drivers side.
Sure was that fuse.
---------- Post added at 10:59 AM ---------- Previous post was at 10:58 AM ----------
Got it read. I have a P0446 code and no idea where to start.
BRUTUS_T_HOG
You have a part number?
Ok looks like the pickup models have the remote mount filter and the SUV bodies use a better vent valve with a revised internal filter.
Revised bracket P/N 15105605
Revised Vent Valve P/N 10382105
PM me if you want a copy of the TSB which includes pictures and installation instructions. EDIT: only the pickup model TSB included pictures
Keep in mind this doesn't take the place of a proper diagnosis, at work I would smoke test the evap system and command the vent valve on and off multiple times.. they typically get stuck after a few tries.
bsu31
