Where to run wires
BLKTah02
Looking to install a new stereo with amp and sub, what access points do i have or can run through the firewall for these wires???
Gzes
the drifting 2dr
Wichita tx
The only firewall wire you need is the amps 12 volt the rest can be one in cabin
BLKTah02
BLKTah02
yea thats the one i need that goes to the battery, its the power cable one, but where can i snake this wire through??
Gzes
the drifting 2dr
Wichita tx
Mine doesnt leak or anything i just found a bare spot and drilled the hole. People use rubber rings for the hole but i didnt n it doesnt leak so its good
steven johnson
wisconsin
craw under truck ,check under driver seat might find a knock out plug. if not then the fire wall . i did my about 3" from rear of the engine (driver side). drill small hole and fish a wire thru to see were it comes out . mind came out right above the gas pedal. when you run your power wire used a rubber ring to protect the wire, also caulk around the hole. good luck.
BLKTah02
BLKTah02
found a spot but now having a hard time running the 4 gauage wire under neath the trim?? seems impossible even with a smaller power wire
blue99tahoe24
bout that tahoe life
joliet il
I ran mine under carpet next to the trim piece
Sent from my PantechP9060 using Tapatalk 2
djnmel2020
