uneven wear
kjhjr
I have a 2002 Suburban with 26 inch wheels and 259/30/26 tires. The driver front tire is wearing out on the outer side of the tire. I went to PEPBOYS and was told I need a heavy duty suspension in the front to handle the wheels size and to correct the outer tire wear. Can anyone give any advice on what I should do?
electro
Kitchener, ON, CAN
I am in the process of dealing with a similar issue.
My tires with toed in too much causing them to feather on the inside of the tire.
So now they vibrate intermittently at high speed.
Alignment man said I need a quality alignment done.
I have yet to get this done, he's thinking its going to be around $600 CAN. Included in that is going to be some kits for adjusting camber (100 bucks a pop). This is supposed to make it easier for him, I thought the truck has adjustment ability for camber.
I am also confused with my issue here.
TheSuspensionSource
Supporting Vendor
Fresno, California
This is Belltech's Front Camber 2 degree Bushings. This will help 99-12 GM Trucks and SUVs get back within alignment.
I would also recommend using Belltech's Street Performance shocks.
a4edwin
ny
i got the same prob but it's both driver and pass side. pass tire is wearing out alot faster.
rxl13x
