Sea foam
roadrageror
roadrageror
ROADRAGEROR
alberta,canada
my Sea foam already showed up!! i ordered it June 27 @ 7:00 pm. Texas to Alberta,Canada..actually my front door July 2 @ 3:45 pm. Quite impressed! i ordered a 6 pack gonna do 4 vehicles on saturday. 2000 dodge diesel,1999 denali,1991 blazer(full size)1988 chev s/b.keep a couple of bottles for a later date.
99COOP
Retired
Chicago, IL
i hope yall like it i just got a rebuilt engine in my truck im gonna run it every damn oil change
thats a little overkill, it wont really help at every 3000
Isn't there a SeaFoam intake cleaner too? Maybe something you suck in via a disconnected vacuum line?
Thats how normal intake is done to cylinders in the engine with about a 1/3 pint of seafoam. They make a spray cleaner for the throttle body and the intake called "deep creep" that works great too. thats a more involved process then just seafoaming through a vaccum line.
texaschevyryder
LAWTON,OKLAHOMA
when do you suggest runnin it on da new rebuilt engine
Dr. Overkill
El Cajon, CA
Reason I asked is because I just manually cleaned a throttle body on the F*rd 460 in my motorhome, and I still want to clean the manifold but I DON'T want to have to remove it to do so. Too ugly a job. Was hoping there was a good DIY method for that part of the job.
The backside of the throttle plates were black and nasty. It had a slight catch when pressing the gas pedal down off idle it was so gummed up. I expect the manifold will need more than one cleaning--or do you think one 1/3 pint shot of Seafoam would be enough?
YNOT
im afraid to run seafoam through the vac line with 104,000. i think i'll just put lucas in mine and the wifes gas tanks.
99COOP
Retired
Chicago, IL
honestly if your engine was fully rebuilt you got some time before you really need to do it. Run some nice oil through her at every change and that thing will be clean as a whistle. But serisously maybe in a year or two you could seafoam but it really wont need much cleaning. -your lucky
I would try and clean by hand as much as possible, its a PITA but well worth it. Then run a 1/3 pint through and you will be amazed, but some in the gas (believe an ounce for every gallon, run to empty and then refill) that way you will clean out the lines and injectors as well.
Oh dont worry about it, with 104 its prime for some seafoam, pull in a 1/3 pint through the vac line, wait 20 min, and watch the magic. it will do wonders, i just did mine 300 miles ago and have 213,000 miles on the clock, 104 was just breakin her in :)
jdawg901
memphis tn.
Can u just pour it in the tb or will u get better results through the vac line
jonnybalo
