Lemon Law California. 360 camera keeps going black
mountie
If your dealer accepts ANY attempt to repair "as per your complaint", MAKE SURE THEY HAVE IT IN WRITING PER DEALER...... They will only attempt a factory warranty item. If they do make an attempt, and fail...... many times the 'failed repair' becomes an ongoing complaint WITHOUT A YEAR/ MILEAGE LIMITATION. ( I lived in California)....... But dealers may blow you off due to this fine print. (( read your warranty..... This may be written in there somewhere. ( It was in my warranty book) But that was a while ago...... It may have changed since then?
Oh, yea..... CHECK FOR A "TSB" ( Technical Service Bulletin ) on your exact concern. Others may have a same issue...... GM won't volunteer this report of a defect...... But the TSB must be described same as your complaint. Make your complaint same as the TSB description. ( If there is one)
tatheho
