HELP !!!!! With Dome Lights SOLVED ! I'm a little dumb. The dimmer dial was turned up all the way
Foggy
KS
Out of the blue, My dome lights won't turn off
No matter what I do. I know none of the 4 front doors are "bad" or misreading as
the power running boards go in and out correctly for all 4 doors independently
I can't even use the dome over ride switch... Or even if I start driving.....
Dome lights stay on
Help !!!!
I've pulled the #5 courtesy light fuse inside the cabin, but I don't know what else I'll lose
with that circuit dead....
And of course I don't want a dead battery
Dome lights stay on
Help !!!!
I wonder if that switch assembly is faulty. Know anyone with a similar vehicle that'll let you try their switch as a test?
F
Foggy
KS
No I don't... I figured if the override switch was "bad" it would stick in the OFF or override positon... just because there is no "always on" position....
F
Foggy
KS
I'll check and see what that new one runs....
OH Crap.... I never checked to see if the dimmer dial was turned all the way UP to
the dome on position
THANK YOU iamdub !!!
I;ll run out in the morning and check that too
I had it in my mind it was the over ride off button
I didn't mean the button specifically. I was thinking the assembly as a whole, like a fault in the PCB. You kinda ruled out the door switches (the ones built into the latches) so I was thinking something else in the chain specific to the lights. Kinda like how a defective multifunction switch can keep high beams or turn signals from working.
Hoping it was just a derp moment!
DOC1583
