Front 4wd noise under acceleration
sealandsky
Minneapolis, MN
I'm curious as to how often you are driving around in 4 auto mode? And for that matter - under what conditions are you driving in 4H?
BlaineBug
Clown World
Mine makes a distinct deep noise under load as well when in Auto or 4-Part Time. I too changed fluids early just as preventative measure. I'm not sure if it's front differential or transfer case related, but I am not concerned.
Timothy Sargent
Changing the shaft worked...
Can you elaborate more? I'm pretty much having same issue you described 2018 Yukon Denali, 50k millage. Under acceleration less than 20 miles per hour there's a rubbing noise. Brand new tires and fresh fluids didn't solve.
Triplearon
