Burban22
- Joined
- Jun 25, 2023
- Posts
- 123
- Reaction score
- 142
From some YouTube videos, I’ve educated myself on monitoring short term long-term fuel trims to diagnose intake, leaks, or bad oxygen sensors. I recently replaced all four oxygen sensors new spark plugs new wires suburban runs very good but fuel mileage isn’t the best 14-16 on the highway at 70mph.
It starts and idles fine, but on hot days, when shifting between reverse and drive idle will drop very low seems like it will almost die, but has never died. I cleaned the throttle body plate, which helped a little.
What do you think of the fuel trims in the video below? From what I’ve learned 3% plus or minus for short term field trim is considered normal. Long-term fuel trim should be under 10% plus or minus.
Seems like Bank 2 (passenger?) has maybe a small intake leak?
Computer has been Blackbear tuned.
Exhaust manifold gaskets replaced and broken manifold bolts replaced.
No CEL codes just trying to get the best mpg from this pig
