Professordeez
- Joined
- May 20, 2023
- Posts
- 5
- Reaction score
- 5
Hi, I have a 2017 Yukon that I replaced suspension on with a strut masters conversion kit. I replaced the front shocks first because they were toast with plans to do the rear later. They also had a module with the kit which was on back order and came at a later date. We lost the module I know.
So fast forward to from last October, when I replaced the front shocks, to this past week and I finally get around to replacing the rear shocks and coils because we are leaving for Orlando which is about 700 miles from where I live. Got it done no problem except the air compressor runs and hisses because the hoses are not connected to anything.
I bought a module from xineering after reading some of these other threads before I replaced the rear shocks because I was having the service suspension code which was causing it to go into limp mode and only 84 mph. I put that on and it clears the code but still the hissing from the compressor.
So I unplugged the compressor and boy was that a mistake. Got a service leveling code that you can’t clear. So I plugged it back up. Then I found a “pull the battery and rtd fuse” work around and tried that. That stopped the compressor but back to the service suspension code even with the xineering module and back to limp mode.
So my question is what do I do to stop this compressor from running? I’ve searched everywhere and can’t find anything.
Thanks
Thanks
