BlaineBug
- Joined
- Dec 29, 2019
- Posts
- 1,132
- Reaction score
- 632
Update. Stretch belt seems to be working great - no more problems with the belt slipping off so far. I let it sit for 3 days in colder temps and fired it up yesterday afternoon to take it to the grocery store. The initial compressor engagement took about half a second and was much less harsh than before adding the deslugger. After that, every time the compressor engaged it did so normally. As far as I can tell, the deslugger only engages on the first compressor engagement, and only after the ignition has been off for at least 30 minutes. That suggests a revised design than what @gooffeyguy described. I can see no downside to it at this point but I will keep an eye on it through the summer and report back.
Also, I used a sliver sharpie to mark the harmonic balancer as Don suggested and there has been no movement between the inner and outer parts.
From Four Seasons:
The Deslugger is a patented compressor clutch timer that is designed to help prevent “slugging” in low mounted compressors after the vehicle has been sitting idle for over 30 minutes or longer. Upon the next start up, The Deslugger is designed to gradually push oil or liquid refrigerant out of the compressor before it fully engages, relieving the possibility of a catastrophic system failure.
