06 Escalade cargo cover?
BlaineBug
Yes, because they're in a lower position.
I did not know that! So essentially, if you have a Suburban or Yukon XL, although you have more square footage in the cargo area behind the third row, you won't be able to cover something as tall as you would in a short wheel base SUV?
Not positive on that as I never compared lengths of both to each other, but the swb cover isn't wide enough to lock into position in the lwb. The difference between both is 2"'s.
BlaineBug
The suburban body is 2 ft longer than the Tahoe's body.
13" longer actually, yes. What I was saying is that I assumed that the cargo cover for a Suburban or Yukon XL would fit a standard length Yukon or Tahoe.
BlaineBug
I stand corrected. When I was buying my 2019 I had looked at the numbers. I felt as though the XL was 13" longer. But verifying the data again there is still a 20.5" difference in length, although the length of both short wheel base and long wheel base has grown since 2003.
2019 data for overall length;
LWB: 224.4"
SWB: 203.9"
I believe I was mixing up the WHEELBASE as the 2019 has a difference of 14" between short wheel base.
2019 data for wheel base length;
LWB: 130"
SWB: 116"
Once again I do stand corrected. I'm not sure where I was getting the 13" figure from as it relates to nothing.
By the way for S&G's the 2021+ models aren't quite as different from one another. The long wheel base barely grows by 0.8" but the short wheel base grows by 6.1".
2021 data for overall length;
LWB: 225.2"
SWB: 210"
2021 data for wheel base length;
LWB: 134.1"
SWB: 120.9"
And for even more, here's some data from the 2014 lineup. The wheel base figures are exactly identical to the 2015-2020 model year but overall length varies ever so slightly.
2014 data for overall length;
LWB: 222.4"
SWB: 202"
2014 data for wheel base length;
LWB: 130"
SWB: 116"
rockola1971
Indiana (formerly IL)
LWB: 224.4"
SWB: 203.9"
LWB: 130"
SWB: 116"
LWB: 225.2"
SWB: 210"
LWB: 134.1"
SWB: 120.9"
LWB: 222.4"
SWB: 202"
LWB: 130"
SWB: 116"
Not sure why you are quoting specs from 2014-2019.......in a 2000-2006 subforum. If the wheelbase gets longer so does the body.
BlaineBug
My assumption was that the width of the body didn't get larger when the wheelbase and body gets longer.
BuckWild62
