Interior electrical problems
druiddonn
Everything was working fine now I have no power windows no power locks no radio gas thermostat battery oil pressure or transmission temperature gauge what is here your dome lights don't work but the map lights do I've checked all fuses and relays I have power to the driver side window switches driver side power mirror still works passenger side does not
Diagnostic port does not work
Information center says driver unknown and when I turn the vehicle back off I sometimes get odd codes numbers or just random pixels
04 Denali XL
I've been troubleshooting this for a day-and-a-half any advice would be greatly appreciated I do have an after-market radio that I've completely removed and continue to have the same
BentleyArnage
Washington
Disconnect the battery and touch the terminal ends together. Not on the battery. The disconnected positive and negative cables. It will wipe out the memory. Hook it back up and see what happens. If it doesn't know the driver, then you have something going on with the key and the steering hub. I suspect you have several problems. A cheap scanner won't find it. The cluster may need to be resoldered. It's common for the solder joints to crack. Make sure you check all fuses and relays. This is just a start.
druiddonn
druiddonn
Thank you all my research and troubleshooting so far has led me to believe it's either something in the key or the body control module
druiddonn
druiddonn
Try that and now I have no power at all
Letting it sit for 20 minutes disconnected hopefully that will solve this new problem
BentleyArnage
Washington
If you're without power after a hard reset, you may have blown a big fuse. That's not the normal reaction to a battery disconnect. BCM may be a problem, but you'd see some communication errors crop up on a scan. That's another reason you can't use a cheap scanner. They don't address can buss issues that are prevalent with BCM problems as well as instrument problems.
druiddonn
druiddonn
I jump started it and got it running the radio came on for a minute or two but no sound out the speakers still no communication from the diagnostic port diagnostic port does power on the scanner
exp500
Based on your descriptions, Check your battery cables and Battery, then fuses. Something possibly unplugged/loose under dash on BCM harness. No OBD port power is hint.
