GMT900 Bose Premium Amp to Luxury Amp Upgrade
kbuskill
NE. FL.
I’m looking to buy a 2012-14 Tahoe. I’m seeing one listed with a Bose Centerpoint 10-speaker. Is this the Luxury Bose? What do I look for to know that I have the Lux or the better Bose setup?
Thanks
Yes... center speaker in the dash is the obvious give away that it is the LUX Bose amp.
Also you can look for RPO code Y91 in the glove box.
chaingun427
OBS Mad Scientist
Mooreland, OK
I apologize for necroing a 7 month dead thread, but I'm coming from a bit further out on my setup.
I have a base model around system, I'm going aftermarket for the head unit, but I like the idea of having an oem well packaged solution that retains all the factory crap.
Anyways, is there any programming necessary to get the amp to turn on, aside from the head unit? I'm assuming nothing with with bcm since the premium amp doesn't have a gmlan connection. I havent hooked it up to any inputs or anything yet, but I assumed that when connected to power and Lan I'd get some sound from the door chime to confirm its powering on.
The amp works fine in its donor denali if I plug it back in there, so I'm sure the amp is good
kbuskill
NE. FL.
So to clarify, you have a non-Bose truck, correct?
And you are trying to install the (standard) premium Bose amp or the Luxury amp?
I assume the Luxury amp since you mentioned it coming from a Denali, but wanted to verify.
I know on the standard Bose amp the door chimes and turn signal sounds are built into the factory head unit.
chaingun427
OBS Mad Scientist
Mooreland, OK
"luxury" amp from an 08 denali. That's part of the reason i'm trying this. I know that the amp will power on entirely without a headunit present, and generate the chimes in the denali without a head unit. I assumed it'd pick up the same GMlan messages in the non bose trucks but maybe not. I'm fixing to go out and put power to the amp through the harness for the first time, and reprogram my maestro RR just to see what happens
kbuskill
NE. FL.
I would think it would too but can't say for sure.
How are you wiring up the Luxury amp since your truck didn't come with a harness for an Amp in the console?
chaingun427
OBS Mad Scientist
Mooreland, OK
Access to all data, gt150/280 pins, and a couple miles of wire lol
Sent from my SM-N975U using Tapatalk
if you wired it properly then you program the maestro for bose and it will send the digital signal to turn on the bose amp
***also there is a glitch with the meastro and bose if you set the maestro to keep the headunit on while cranking it may not send the digital signal to turn the amp back on, by default that option is off but just heads up
thathighlife7
