NORCAL SS Custom 2/3.5-4.5 for all 2wd 2015+ GM SUV
fratzke7
I just installed my kit and now the suspension leveling system light came on the dash?
fratzke7
Yup I text him and got me all squared away..my installer forgot to connect the autoride adjusters
Fsuhammond
Was just about to place an order and watched a couple videos where new rear sway bar end links are needed. I don’t see these mentioned in the kit details. Any clarification is appreciated. Thank you.
lynxnova
New Jersey
I have the 15 non mag or air, did the belltech 2 front 3.5/4.5 rear and the rear was slammed without the spacer... i think it looks great... so i ordered belltech struts for front to go another 1.5... so ill have a 3.5 front and 4.5 rear but i thought rear that non mag or air was even lower like basically 5 inches without the spacer...can anyone comfirm?
Also will I need new uppers? So the front ball joint isnt so raked?
Running 24s 295 35 24 here is a pic from yesterday
Nice truck mentalmadness, seems like I have the same drop where the front only went down 1.25” after installing the 2” spindle. Did you order the strut cup to go another 1.5” lower in front? Is so can you post and pic and did you have any alignment problems? Thanks in advance
KennyK
i had the same issue with only getting 1.25 out of the spindle. i ended up getting the struts to lower the front some more
lynxnova
New Jersey
When you say strut, do you mean the strut cup setup or just new struts?
GranPrix
@NORCAL SS Tony do you know if you HAVE TO change the knuckles when lowering? I have an LS hoe and I'm swapping the springs and struts for PPV springs and struts. But I noticed the PPV and civilian models have different knuckle part numbers... does anyone know why?
mbp1979
North Little Rock
Ones probably an aluminum one and ones probably a cast one. That's would more than likely be the difference.
Kaptainkhaos58
