P061B check engine code stall out
BG1988
so the transmission is bad? I just resonantly washed the car at the car wash on the 16th maybe it got water somewhere it should have not??
there might be some other codes I got rear ended as well..... Good thing I got the hitch thing.. THAT IS WHY YOU DONT TAILGATE I just let it go and parted ways..(as he was at fault..... ) i did go to auto zone so they can pull the code etc.. just in case and got a hard copy.. of it and it's still stored in the ECM
it says failed P061B= ECM or control module or torque calculation performance condition..
this was the only code..
the engine was able to be successfully restarted many many times as well as autostop resume.. sigh...
B
BG1988
@swathdiver is a whiz at codes along with a few others. Did you spray inside the engine bay?
no :) just a standard automated car wash that 100s of cars use everyday. i might have nudged the high voltage disconnect while vacuuming should i resit the HV connector?
Big Mama
Virginia
I’ll let @solsea handle the reset question. Is it that easy to jar loose? I’ve got zero hybrid experience.
B
BG1988
it ran fine today I got the minimum expected city MPG(as i had the A/C on as not to overcharge the battery) i ran it in M4 so it would not turn off (v8 mode only ) i'll check it out tomorrow.... i'll also check out that Transmission cable
Azwood12
