Scottydoggs
NJ
Old girl had a bath today after I put the new power steering lines on last week and she had to sit for a while. I think the power steering has messed up the rubber bushings and such on the whole front drivers side. d430633af17e6329a2e173ebb9f391da.jpg
Sent from my SM-N975U using Tapatalk
love that green. wish i could have found one when i was looking. i had a polo metallic green gmc pick up i bought new in 03.
mwilson62000
Tues evening, walked over to see my neighbor and as I walked in front of the Tahoe, noticed a big puddle under it. Coolant:banghead: Pressure tested and it was the water pump. Finished up replacing it along with belts, upper and lower hoses, tensioner, and idler pulley.
TheAutumnWind
Shifter moves. Feels a little loose. Truck wont come out of park. Brake lights work. I can grab the linkage at the trans and change gears. Any ideas?
When I put it in neutral with my hands I can use the shifter to put it back into reverse then park. But cannot shift down out of park
brian.roberts.1293
Durham NC
Sharp! Love the color.
Yeah it was one of my favorites Chevy has
They are not all that common where I'm from
Paint looks great.
Thanks bro I'm trying to bring it back. Learning to use a DA polisher
Looks good brian
Thanks bro
Thanks bro
Had the same problem with my van. I had to replace the shifter cable. I bent it near where it's bolted to the trans pan and it got messed up internally. My guess is it's your shifter cable--most likely the 2nd half--it's 2 pieces.
What color sem have you guys used for the pewter/dark pewter interior, I bought some and it's too light need to get the right can
n240sxlover
