Looking for a high output alternator.....
wendal
Dallas
I'm looking to upgrade my oem alternator to a high wattage alternator. Has anyone done this?
Can you give me pointers/links to good ones?
Thanks in advance!
Wendal
Sent from my ONEPLUS A6013 using Tapatalk
wendal
wendal
Dallas
Thank you both. I went with the ebay one recommended by @Doubeleive . Yeah, that $500 thing was making me hesitant. I could buy 2 of these and not hit that number. Thanks!
wendal
wendal
Dallas
@Doubeleive , did you have to change the fuse on the firewall with the high output alternator? The default is 175 amp. did you upgrade this fuse?Which Wire Question.jpg
@Doubeleive , did you have to change the fuse on the firewall with the high output alternator? The default is 175 amp. did you upgrade this fuse?View attachment 222161
no I didn't mess with the fuse, I don't think that is related to alternator output I believe that is intended to be a fusible link in case of a short circuit. but I am just guessing based on how it is installed in the trucks
SnowDrifter
Washington. The desert side not the Starbucks side
I've used DC power in the past with great success. Don't know how much power it actually put out cause the damn thing sent my 400 amp clamp meter into overload. 390xp unit.
Mechman makes great units too
I know they're pricey, but trust me, it's worth the cost. Cheap ** alts either don't perform, break, or both. Buy once cry once. An alternator is a critical part of your vehicle and best case, will leave you stranded. Worst case, will blow out any electronic bits that aren't high voltage protected. I see too many alt failures in my neck of the woods (audio gear) to be cool with cheaping out on them
Don't forget to do your big 3 upgrade! Use OFC. If I see you use CCA I'll kick you in the ding ding :)
this one I bought and linked above is just a rewound oem dr44g same thing I had on my nbs never had a problem, I have a 5000w orion and (2) 12w6, 0 gauge and dual agm's, no flickering or dimming etc, the orion is turned down a bit because the 12w6's cant take 5000w
wendal
wendal
Dallas
@Doubeleive and @SnowDrifter , How do you test the output of an alternator? And Yes, I did a big 3 + about a month ago, with OFC (welding wire). I say + because I ran a new ground to the frame and one to the body, in addition to the one to the engine block. I also ran a ground from the engine block (alternator mount) to the body, where the wire strap mounts. The grounding eliminated my stereo system whine through the speakers. Let me know how to measure the amps coming from the alternator. I have a voltage meter, but don't really know how to use it (duh). Thanks in advance!
