DRL/Turn Signal Mod with a twist... Sequential Signals
qcon
Huntsville, AL
I did the DRL mod using the tutorial here about a year ago that ties both bulbs together to function as DRL/Parking/Signal lights, and I was generally pretty happy with it. I liked the added volume that the lights had when working together. After seeing Kbuskill's sequential mod, I was inspired to do the same with my lights, while retaining the functions of the previous mods.
I'm not very good with electronics, but I got it figured out using some Amazon sequencer modules. The thing I don't like about these modules is that they fire 1,2,3. I would rather they fired 1, 1+2, 1+2+3 so the at some point all bulbs are lit.
kbuskill
NE. FL.
I mentioned in the other thread that I will probably be switching out my modules for a better set that I already have. The ones I have are the same style I used for my sequential Esky 3rd brake light and they stay lit until the sequence is complete, as described.
qcon
qcon
Huntsville, AL
What is the new module you're going to use? I can't seem to find one that works the way I want.
kbuskill
NE. FL.
I have a spare set of the older 10 channel version of these....
https://corsomotion.com/collections...ntial-controller-module-10-channel-ver-1-each
I had the 10 channel version on my Esky 3rd and burnt up the 10th channel so I upgraded to the 12 channel which has a higher amperage rating (.75A vs .5A)... still burnt the 10th channel on one side... need to open the Esky 3rd back up and figure out what is causing the extra amperage draw.
They keep each channel lit until the sequence resets.
qcon
qcon
Huntsville, AL
That's exactly how I'd like it to function. It looks like I would just need two of the modules and 2 cases? Since I'd only be using 3 bulbs, I would just wire in channels 1,2,3? They don't have any install or descriptions on the page. Thanks for the lead!
kbuskill
NE. FL.
Yes.. 2 modules and 2 cases.
Just a heads up... the new modules are quite a bit smaller than the old ones and when I got the new versions they didn't have a case that was the correct size.
The new modules will fit inside the old cases but the cases are really to big for them.
As far as wiring them... you could use channel 1, 2, and 3 but the flashes will be very fast and the sequential effect (or rice effect if you prefer... lol) won't be as noticeable.
I will probably use channels 1, 5, and 9 to slow down the sequence a little.
qcon
qcon
Huntsville, AL
What a big size difference. What are the dimensions of the case? Thanks again for the info.
kbuskill
NE. FL.
I don't have them in front of me but they are roughly 3"x4"x1.5" thick.
804getSome
