NORCAL SS Custom 2/3.5-4.5 for all 2wd 2015+ GM SUV
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
That is up to customer. 4 shocks belltech are 300 extra.
If has higher mileage I'd swap
ulakovic22
Lantana, TX
No, your pick up points on the front don't change with a spindle, so factory shocks work as designed. If you were lowering using springs, then yes, you would need to look into changing it up. On the rear you are able to get around that by using the extenders.
crazycrew
Vacherie, LA
Anyone have rod measurements for a XL or burb with autoride and NO rear spacers? Spring and idolaters only on rear.
crazycrew
Vacherie, LA
crazycrew
Vacherie, LA
Makss
Just picked-up a 2018 Tahoe premier RST 6.2 4wd and it sits too high. Interested in the 2/4 kit. One question: will the drop spindles work with the large Brembo calipers? I did not see a thread to confirm this detail. I want to confirm fitment before ordering.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Yes they do. I've done quite a few
Dearmosd
anyone have ground to fender measurements with stock 22" rims?
mentalmadness
NW Ohio
Im.sorry been running. This kit has been working out great.
We can also set up a 3/5-6 kit.
These trucks you can do 5 and be fine. As long as you cut bracket off frane your fine
I have the 15 non mag or air, did the belltech 2 front 3.5/4.5 rear and the rear was slammed without the spacer... i think it looks great... so i ordered belltech struts for front to go another 1.5... so ill have a 3.5 front and 4.5 rear but i thought rear that non mag or air was even lower like basically 5 inches without the spacer...can anyone comfirm?
Also will I need new uppers? So the front ball joint isnt so raked?
Running 24s 295 35 24 here is a pic from yesterday
jeffsyamaha
