100k service?
Bombsquad85
Bombsquad85
Northern VA
you'll also want to closely inspect (for wear) your steering components (tie rods, end links, bushings, front wheel hubs and shocks (front & rear), flush your cooling system if that hasn't been done already. check your brake calipers for leaks. basically anything under the truck should be visually inspected, excessive grease on anything is a indicator that it's worn or getting worn. a flashlight and taking the wheels off helps to look over everything.
Suspension is my #1 game plan right now. I think in the near future I'll be doing UCA, inner/outer tierods, pitman arm, idlers arm and bracket, and another alignment. Then I'll move on to fluids, I'll do the diffs, tcase, coolant and brake/psteering fluid. Then I'll do transmission fluid and filter them fuel filter and clean injectors. Then plugs and wires. Hopefully I can do this all by the end of the summer.
Hopefully that will net me a much better ride and a happier healthier engine/drive train. Maybe pick up some power and mpgs
Bombsquad85
Bombsquad85
Northern VA
While I'm on the topic of maintenance anyone have a suggestion for P0496 I think it is? I've done fuel cap, and evap canister. I hear something about a fuel pressure sensor that's on top of the tank or something on the intake manifold
there is 2 evap solenoids, one is on the engine intake manifold (easy to change), the other is down under the truck above the spare tire and connects up with the evap canister (that you already did), I recently did all off them on my 2012 and it took maybe a couple hours and I was doing other things and being interrupted.
Walkercraig01
I think that's the most common fault code I have seen for these vehicles lol
Big Mama
Virginia
Not sure if 05 has cabin air filter and might have an AC tune up. Didn’t see belts mentioned and little stuff like door hinges left gate and hood struts lube them
Bombsquad85
Bombsquad85
Northern VA
Thanks. I did the one next to the spare. Do you have a pic of the engine bay one?
I don't think it has a cabin filter. The belts look good but I'll keep an eye on them.
Thanks for all the info. I did a quick Amazon search for a lot of parts and so far I'm at $630 lol
Bombsquad85
Bombsquad85
Northern VA
My OCD is kicking in because all of the parts are Prime except for the idlers arm bracket....
:yuno:
HiHoeSilver
Away!
Chicago
:yuno:
Two things I see.
Forget that fuel filter. Your truck doesn't have one. Yours just has the pickup screen in the pump. Also, do a little search on the moog arms. There have been fitment issues with one of them I can't remember if it's the idler or pitman. Guys were using AC delco pro for that one part instead of the moog.
View attachment 202326 View attachment 202328
yours may be a different part number, but it looks just like this and sits on the top of the intake near the front
https://www.ebay.com/itm/00-01-02-G...Denali&hash=item1caa39a487:g:E7sAAOSwUKxYbopQ
Walkercraig01
Two things I see.
which ones don't have fuel filters just for general knowledge lol
Bubba6
