2016 Yukon rear suspension stiffening
DStockton
What is the cheapest and easiest way to stiffen up the rear suspension on a 16 Yukon slt non towing package. I do not have the auto leveling shocks. The ride is amazing when driving normal but when I put my boat on there it sags a little bit. Is there a quick fix?
Sent from my SAMSUNG-SM-G930A using Tapatalk
D
DStockton
What about replacing the bump stop?
CMoore711
With what something bigger? That would make your ride terrible.
As already mentioned, some air bags "helper bags" contact Tony he has a set-up he's been installing. I'd also look into adding some beefier sway bars as it will reduce body roll and some of the lateral "softness" you may be feeling while towing.
sickk23
New Mexico
Rear air bags are usually what people throw in there to tow more so level and not squatted.
dbbd1
You could also lower the rear (level or drop the front too). That would help stiffen the rear too.
And then there are sway bars. My hellwigs go on tomorrow.
sickk23
New Mexico
I can’t see how lowering would help with towing, would it?
Laurents10
