00-02 to 03-06 seat swap???
Than you’re the oddball :D:p
I guess I'm the only oddball. I've seen the airbags in the leather equiped trucks, but I've never seen them in trucks with cloth. Mine doesn't have the seat airbags. If the front seats had airbags, there'd be the AIRBAG tags on the sides of the seats on the upper/outer bolsters.20180312_082430_001.jpg 20180312_082503.jpg 20180312_083456.jpg
Rob88
Rob88
Citrus County, Florida
The airbag plug is the same. I swapped my 02 Denali seats for esky seats from an 04 and the only thing I was able to use was the power and ground to have the move, only downfall is that memory and heat is lost.
that's a-ok with me because all my original seats had was power slide forward and back, the rest is manual with no memory or heat. Thanks for the info.
inmypassatlife
Had anyone done this? I know the seats bolt up fine, and I'm aware there are some differences in the plugs for the power controls. What concerns me is the airbag compatibility. I remember someone saying once that its a different type of system for 03+ for the wheel and dash, but I cant find any info on the seat swap.
Just replace the seat cushion and the cover, that's the main difference. I have an '01 with '03+ leather
coffeeguy
