Cold Air blows on front Passenger seat feet in winter
okfoz
I have had this problem since I purchased my 2007 Tahoe in 2014. Here are the conditions
1) When the car is stopped, it is fine
2) When it gets really cold, and while driving down the highway cold air blows in onto the front passenger's feet.
3) Even with the heat up all the way to 80° there is Heat from the Left, and Cold from the right.
I was wondering if this is normal, or a hole somewhere I need to plug up.
John
could be a broken blend door or bad actuator I don't think there is really any hole to plug
do all the adjustments work normal? and by that I mean when you adjust everything hot/cold, up/down, does it actually blow the air that way
O
okfoz
It seems to work otherwise perfectly, no funny popping noises, or no heat like a bad actuator... Wife says the cold air comes from the right side, which I do not think there are any ducts over there
Of course this only happens at speed (55-70mph) and it is not coming from the ducts, it is like something is blowing in from the outside.
It has me baffled (no pun intended)
John
Seems to me one of your temperature valve actuators has gone bad or is out of synch. Probably the passenger side one which is behind and to the right of the center vents. Do you have a Tech2 or know someone who does? It can see the internal BCM codes and can see the commanded and actual counts of the various actuators and of course perform a relearn to reset them all.
John
might try a small strip of paper held in the fingers and see if she can pin point exactly where it is coming from and investigate further, could be a tricky one, there is a plastic cover under the glove box that hides all the plumbing for the heat/ac ducting, you can remove the 2 right most screws and pull it out some at an angle and that may help to find where the air is coming from.
PG01
Up here to the right
Take all 4 screws out and check, you’re there anyway....
cpellegrino
