Leveling kit, tires, wheels, grill installed- 2015 Yukon
MisterCrab
supermaxx will sell you just the relocation bracket needed for autoride and magnetic ride ask for john he will help you out
I tried suspension max system but the ride was terrible. Ended up going back to all stock. Problem was, when I lifted the front the autoride lifted the back. I used the brackets and everything. Any advice??
Adam10532
How big of a lift did you do in the front? What I originally did it I had the same problem so then I took off the relocation brackets for the autoride and put it back to how it came from the factory and then I got a level ride
blarose777
I've got a very similar setup to Denton (2.25" level, same tires) and I have not experienced any rubbing and no trimming was needed.
Do you think this tire size would work with a 2" rough country or the billstein 5100 which gives about 1.7 inch lift to the front?
Demer
Eagle, ID
My guess would be, yes. I don't think that final .25" would make a difference for tire clearance, but would help with level.
blarose777
Did you have a lift on the back? Just wondering if the rear will have any issue at all or just mainly concerned with the front
Thanks
Demer
Eagle, ID
Thanks
Yes. I did 2.25" on the front and 1" on the rear. Just a very slight rake it now. I think a 2.5"/1" would get it just about perfectly level.
Trickystick19
