Autoride....again
Yukongk
Yukongk
NY
A miracle took place in NY today! I started her up to move her a few feet so I can wash her in the backyard......I heard the most beautiful noise.....the compressor fired up and filled my shocks! All I did yesterday was soak the wiring harness in MAF cleaner, and unplug the SCM while the vehicle was running to see if the service ride control message illuminated (it did).
I want to unplug an air line and deflate the system to see if it works again, but I'm going to my BB tune in a little while and want to feel good about my truck lol.
So the compressors aren't the problem. Now I have a brand spanking new Arnott laying around.
Yukongk
Yukongk
NY
Still not working right. Guys, I think I need an ESCM.
The "wanted" section doesn't get as much attention and I know someone on here has what I need. For those of you that rid of your autoride systems, I need the ESC module that's in the passenger side cargo area (behind a trim panel). I can't locate it anywhere online me local junkyards operate more like overpriced retail stores.
Please sell me one.
Yukongk
Yukongk
NY
Thanks to all who helped. Turns out none of the compressors were bad.
I had an electrical guy diagnose the system and he found a broken wire in the harness going to the alc relay and repaired it. The system works now!!!!
FYI- the dorman compressor is louder than the Arnott. The Arnott is whisper quiet in comparison, but I ain't messing with it! I'm selling the replaced Arnott (Brand new) in the FS section.
OHSIXX
Milwaukee
Glad it all finally worked out....I'd have pulled my hair out by now-I admire your patience/persistence. Electrical problems are a PITA. So the wire was broke or did it corode so badly that it broke? I have an extra ALC relay from my trouble shooting as well lol. Maybe I should have a back up compressor on hand.......
Yukongk
Yukongk
NY
Corroded. Which explains the intermittent/weird behavior before it went out completely. I really thought the ESCM was the culprit, glad I didn't throw money at it.
Zigger21
North Dakota
I ordered an Arnott rebuild kit because my compressor wouldn't even kick on. I rebuilt the compressor plugged her in and it ran for 7 seconds and turned off. So I thought it did it. Its been working great every time I start it up even when I have my boat on the back it pumps it up for about 12 seconds great right. But ever since I cannot get the warning "service ride control" to reset. I pulled the battery for an 24 hours and put a charger on the battery to get her nice and charged. Hooked it up and I still have the warning. I pulled the 30 amp fuse under the hood and that didn't clear it. If its working right what do I need to do to clear the warning without having a Dealership bend me over and it may still not work.
You need resistors added if you are running non stock shocks either in front of rear. There's something called a magnetic damping system that the SCM uses. Do more research!
Searay45db
Philadelphia
Ok people with the Electronic Suspicion...like me. iCaresoft makes a dedicated GM Scanner that reads everything including...yup...you got it, the ESV module, so you can now pull the codes for the suspension. I bought it for $113 on Amazon. Works like a champ. Autel came out with a new scanner, more money, $250 but it does all the models as well.
Link please?
dzg9
