1995 Tahoe blank keys?
derekjl
Anyone know where I can find them other than the dealer? I was trying to narrow down which one actually works for a 1995 Tahoe, but there seems to be many different part numbers, not sure if they are all the same. I'm just looking for a blank key replacement for our 1995 Tahoe.
cheyenne383
Far North Lurker
Healy, AK and NE GA
I've had good luck on eBay. Just make sure you know which letter blank you have and there should be some options out there.
D
derekjl
Sorry, still kind of a rookie. What exactly is a key “letter”? Is this the style of GM key? All I know is it has no chip in it and has the rubber grip with the GM logo.
cheyenne383
Far North Lurker
Healy, AK and NE GA
There's a letter on the silver part of the OEM key,it's the type of blank they used as the core on the older two key model. 1995 might be the two sided key, if yours looks like the one in the link there's only one core and that one should work just fine.
PG01
Up here to the right
Just go to any hardware store, they’ll have a double sided blank, even with a rubber tip, (just the tip) it may not say gm maybe ilco but cheap key dude.
mals
Western Mass
When I purchased my Yukon used it only came with one key, it was not an OEM key, and the peaks and points of it were rounded smooth from use. I actually went to the dealer and they looked up the key code using my VIN and cut me a new crisp key. After that I took that new key to the hardware store and had my spares cut from that. It was $20 for that first key at the dealer, but all the ones at the hardware store were a few bucks each. I put the dealer key in my fire safe with the title and other documents so I will always have a fresh key if I need more made.
Ihaveatahoetoo
