Adding an aftermarket radio to 07-14 FAQ
rtstat
Im hoping someone here can help me out. I had installed a Kenwood DNX893S expensive stereo on a 2013 yukon denali. The features are great and better than the stock. I also have the maestro so i retained mostly everything (lost ability to have 2 channels on the wireless headphones). The problem i am having is with the wireless headphones. I have noticed that it works off and on. When its not working i have to turn the car off and than back on a few times to get it to work. I had it at the GMZ dealership a few times. The first time they said it was the IR transmitter-i replaced it and i did he same thing. The second time, they told me it was the control module, they replaced it and it still did the same thing. I also took it to the car stereo place that did the install and they checked the kenwood out and said the problem is somewhere in the wiring because everything was working up to the factory harness. Im looking for help as i just want my kinds to be able to listen to their movie and my wife and i dont have to hear it. any ideas what the problem is?
thindiesel
Baltimore MD.
I see a lot of threads asking about what to get to install a new head unit so figure we should make a sticky with all the info.
This will be updated as you, the experts, give more or correct my information. It has been years since I done one of these and I know products have changed. If you have a suggested part that you feel should be added please provide as much information and a link to the manufacturers website for that part.
Disclaimer: This is in no meant to be completely factual posts and all viewing are encouraged to research and ensure fitment on your vehicle.
OS-5
- OnStar® Radio Replacement Interface for Select 29-bit LAN General Motors Vehicles with or without Bose Sound System. Retains OnStar® system functionality and the Bose factory-installed amplifier (if present) when the factory radio is replaced in a 29-bit GMLAN vehicle. Generates all safety warning chimes and audible turn signal indicators.
GMRVD - Overhead LCD Retention Cable for GM Vehicles With Rear Seat Entertainment. Provides an audio/video signal output from a factory radio to an aftermarket monitor. Also for use with a radio replacement interface to retain the overhead LCD monitor and IR system.
95-3305 - GM Dash Kit
GMOS-LAN-01 - GM 29 Bit LAN Data w/RAP ACC & Onstar & chime retention
GMRSAV
- Factory rear seat entertainment retention harness for GM LAN29 vehicles
GMRSAV-2 - GM 12+ w/Nav RSE A/V Harness
BACKUPCAM - Factory back up camera retention harness for GM LAN29 vehicles
BACKUPCAM-2 - Factory back up camera retention harness for GM LAN29 vehicles with factory navigation
Maestro RR - Web-programmable radio replacement interface for integration with factory systems including steering wheel controls, media player, hands-free telephone, voice commands, and satellite radio modules. Also displays vehicle information (performance gauges, climate controls, battery voltage, check engine codes and more) with iDatalink-compatible radios. Basic radio replacement features also available with non-iDatalink-compatible radios.
AVGM5 - Provides A/V connections to the factory video screen and A/V input port.
This is an on going thread that I will update as I can.
GMOS-LAN-01 WILL NOT RETAIN FACTORY AMP!!!!!!
thindiesel
Baltimore MD.
I just installed these in 2013 Yukon XL. Bose. No Nav.
Works fine. I installed Pioneer 1300NEX.
PROS:
Super easy.
Works
The OBI stuff it kinda neat
CONS:
I did have to use the supplied microphone from Pioneer. The factory mic does not integrate.
I had to use the Metra supplied speaker for the chimes/blinker sound.
Hard to fit all the wires in Dash
There doesn't seem to be a way to connect the backup camera to the Pioneer screen, but it does show the park assist zones
Overall:
I'm happy with it.
THERE IS AWAY TO RETAIN B\UP CAM.... THERE IS NOW A HARNESS AVAILABLE BY AXXESS.....
thindiesel
Baltimore MD.
LOVE THE NEW NEX LINE.... I WORK FOR A CAR AUDIO SHOP IN BALTIMORE, WE HAVE ALL CAR AUDIO ACCESSORIES USUALLY IN STOCK IF WE DONT I CAN ORDER IT.... LET ME KNOW IF I CAN HELP IN ANYWAY....
rtstat
im not sure what was used, but when it works it works fine. I just have to turn the car off and than on again a time or two at startup. I can tell if its working by visualizing the red lights on the IR in the overhead console. Thats the only issue....everything else works...steering wheel controls, back up cam (except the distance lines are static and no longer dynamic and do not turn with steering wheel anymore). its just odd that it takes a engine restart to make it work. when the headphones do not work, im still getting a picture to the monitor just no sound through the IR transmitter.
rtstat
this was what installed:
I-Navigation, MET-95-3305, AXX-GMOS-LAN-07, AXX-ASWC-1,PAC-GMRVD2,AXX-Backupcam-2, STI-SI42YF, SIR-SXV300,I-Satellite, MET-40-EU10
Paul Nelson
I hope I am not violating any forum rules by sharing an external URL. Here is a link to Crutchfield's Research Garage which goes into detail about the options available on the NNBS/GMT900 Tahoe, Suburban, Yukon, Yukon XL, etc. Crutchfield Research Garage . Even if you do not order the parts from Crutchfield they have a wealth of knowledge and pretty much list all the parts you need based on your Make/Model/Year. If you purchase from them it comes with their mastersheet that provides step-by-step instructions on how to install everything and retain the factory options.
Meber1
I recently added a pioneer 4200nex with a PAC rp5. The issue I'm having is that the factory head unit was the no screen model, meaning the back up camera goes to the mirror. The rp5 integration module came with a harness that connects the factory brown plug, camera/sub/center to the aftermarket head unit, but that brown plug wasn't begins the radio. Where can I find this plug, as I want my subwoofer back. I am extremely disappointed in the outcome and am considering going back to the factory head unit.
Meccanoble
Georgia
You need an additional PAC harness that retains the rear entertainment. But I dont remember the subwoofer being on this plug, it was just the red/yellow/white rca for rear? I bought same setup as you with rp5 gm31 and trying to remember the other harness but its listed on PAC site and instructions. But at the end, you get a yellow RCA that connects to the rear camera port on back of 4200 nex (brown rca port) and below that are the 2 RCA's for subwoofer. The connection for sub from car to PAC is only 1 RCA but the 4200 is ready to take 2 (red/white). I think even if my sub is unplugged, I still get the subwoofer working. Its only if I unplug the specific harness for sub that goes to bose amp that it stops working. Hope this helps.
adamnalicea143e
