2016 yukon xl denali 4inch lift 4wd
Adam10532
I just recently purchased a lift kit from Fabtech it's the 4 inch budget lift kit cost $740 I'm going to run 285 65 18 "32.5" tall and 11.22 wide on a 18 x 9 fuel Vector wheel all black with a Nitto Grappler G2 Tires pictures are coming soon .tomorrow having the kit installed from 4 Wheel Parts in Covina and So Cal . Everything out the door is going to cost about $3,678.95 here are the before picture
20170823_095135.jpg 20170823_095143.jpg 20170823_095245.jpg 20170711_183436.jpg
Miami-Dade
Super Moderator
Welcome from Miami Beach Adam!! Your Yukon Denali XL looks perfect the way is but I am sure it be more awesome when everything is completed.
Adam10532
Adam10532
Yeah thank you for the comment you know I wanted a Silverado but the wife wanted a van so our compromise was with a yukon .so one more other compromise was that at least I buy it 4 wheel drive and put a lift lol
Adam10532
Adam10532
Not real happy idk why the rear end is so damn high it's suppose to be leveled but the ride is fantastic smooth a little noise with tires but nothing outrageous. The tires are nitto g2 285 65 18 absolutely no trimming or rubbing even the 4 wheel parts shop was amazed there was no rubbing. the wheel is a fuel vector 18 x9 5bs 1mm offset
20170825_183930.jpg 20170825_184657.jpg 20170825_184638.jpg 20170825_184704.jpg 20170825_184708.jpg
Adam10532
Adam10532
I have no idea why the rear is so high going to call fabtech on Monday see what they think ..... it should be level
Adam10532
Adam10532
update since this original post I have went to a 2inch spacers in the rear not the 3 inch that came with the lift because as you can see from the above photos it was to damn high I currently have 2.25 higher "2inch spacer " in the rear i cant stand it I called fabtech and they are sending me a 1inch shorter spacer for the rear so I will have a end product of just about over 1 inch rake that will be nearly leveled. by the way to anybody looking for a 4inch lift keeping looking I have a true 3 inch lift all said and done fabtech even told me that do not even have a true 4 inch lift for my 2016 yukon xl denali 4wd it's a 3inch and there 6inch lift is really a 7.5 inch lift can you believe that so I was never going to get a true 4 inch lift i ended up with a fancy leaving kit. i will post pictures once my yukon has a.smaller spacer in the rear.
01Konvict
Boats n Hoes
Raleigh/SML
Glad it's getting sorted out. They told me that kit was garbage. If anyone wants a true 4" then get zone or bds
