Tahoe shakes HELP!!
Joncanana
Help !! I have a 1999 2dr tahoe 4x4 a week or 2 ago it's stared shaking at 2k rpm 30 mph in 3rd and 4th gear. I thought maybe a misfire so I changed spark plugs ignition cap and rotor and wires. Stared right up sounded good but same problem. So got up to 30 mph and put it in neutral no more shake. Put back in drive shakes put it in 4x4 and it still shaked but not as much any idea what it could be?
bunchz71
If it only vibrates under a load, I would suspect a bad Ujoint. More info plz.
is the tahoe lifted ?
If so, how many inches?
Stock driveshaft ?
J
Joncanana
Stock driveshaft ?
It's 100% stock. ( stock drive shaft)
I got under the the truck and checked the Ujoints they seemed to be fine. I went Through almost the whole front end bushings and bearings all seemed normal. But I did suspect it was drive line because it only happens under load.
bunchz71
Does it only shake at 2000 rpms in all gears?
Probably your driveshaft needs servicing. That the vibration goes away at speed while in neutral eliminates the suspension IMO. Your driveshaft could have hit something and got bent but more than likely you need a new yoke or u-joint. Might be something in the transfer case but start with the driveshaft.
J
Joncanana
I'll have to pull out my driveshaft and bring it to a shop to see if it's balanced.
bunchz71
Are you positive its a vibration from the driveshaft, or a possible engine vibration.
Do this: (to test the TPS, Throttle Position sensor)
With the engine running in park, slowly accelerate your RPMS to 2000(this is where you say it vibrates). If your motor spits and spudders at 2000 rpms with the vehicle in park, your tps is bad. It is possible that you do not feel the vibration from first to second, because the rpms may already be higher than 2000 rpms when the shift occurs(both before and after). When the gear goes to third and fourth, your rpms are lower since you are in a higher gear.
J
Joncanana
Seems good
