New AC Delco Dexron VI Synthetic ATF???
DaNoobLi
So I'm about to do an ATF drain and fill this weekend on my 06 denali with 90K and I'd like to transition to synthetic. I found an ac delco dexron vi synthetic on Amazon for what appears to be a good price. The problem is that I can't find any reviews on it (anywhere) and it looks like it was just released sometime last year. I figure since it's ac delco and dexron vi what could go wrong but I wanted to see if anyone here has any experience with it before I pull the trigger.
inmypassatlife
I use the Supertech from Walmart, $4.27 a quart is a steal. It's been good in all 6 of my GMs
MINIz guy
Dex 6 is Dex 6... you can't put that rating on there if the fluid doesn't meet it. You're fine in any Dex 6 fluid, including "cheap" Walmart stuff. I'm planning to do the Walmart Supertech soon
Sasquatch
Orange County N.Y.
When i did my 50k fluid change i used the delco dexron vi. I`m at just over 100k now and ready to do it again and i plan on sticking with delco but like the other guys said you`ll be fine with other brands.
mizzouguy
Lake of the Ozarks, MO
The delco dex-vi on amazon is exactly what I bought for mine for the most recent filter change at 150k. Great price for oem fluid. It's been around since gm switched to it in 2006-2007.
D
DaNoobLi
Well that settles it. I'll proceed with the ac delco. Thanks for the input gentlemen.
D
DaNoobLi
I bought a gallon from Amazon last month and used it for my transfer case (2009). Nothing wrong with OEM fluids. Guess I should write a review, huh?
I'm going to write a review for Amazon. I was just shocked to find none on Amazon when there's tons of reviews on other brands. I was thinking folks knew something I didn't.:emotions34:
Jimconowitz
Do you have the part number for the fluid and is it safe to use in a 2002 2wd 4l60e trans? I really need to do a flush Thanks
DarkHearse
