Horrible Acceleration
troxclair88
New Orleans, LA
2005 Chevrolet Tahoe 4.8 Liter V8
Whenever I change my engine oil, i have great acceleration power for about 300-500 miles. After, my acceleration power decreases drastically. If I'm on a flat road, I have to wait about three seconds for a response from my engine. If I am on an incline, I have to wait eight to ten seconds for a response. Sometimes even longer. I know that I have a check engine light on with an error code for an evap leak. But the light is on right after I change the oil too.
What can be causing such a drop in acceleration power? What can I do to not make it drop? I just simply want great acceleration power constantly. Help?
Kenny D
Crosby, Tx
Any difference in your oil pressure between oil change and 500 miles? Have you tracked down your EVAP issue? I would solve the EVAP issue and then see if it still happens.
troxclair88
troxclair88
New Orleans, LA
Sorry for the delayed response.
I switched out my purge solenoid. CEL stayed off for awhile but eventually came back on. No further success with evap leak.
There is no pressure change.
This has me stumped..
Danny3737
I seriously doubt your issue has anything to do with just changing the oil. I would first check obvious things like unplugged or cracked vacuum hoses, plug wires, etc.
troxclair88
troxclair88
New Orleans, LA
I've had the vehicle tested at a small local shop. Something they called a smoke test. Hooked some canister up said smoke would come out where the evap leak was. No luck.
I've sprayed every vacuum hose I can find with carburetor cleaner while the engine was running to see if it raised the acceleration. No luck.
I don't know what else to do in reference to that evap leak except ignore it (only if I could, huh?), bring it to a dealership, or keep praying that I find it myself.
Could you evap leak really cause no decreased acceleration for a little and then the decrease?
Like I said, stumped right now...
kootamcgrabbin24
