changing wheels need suggestion
HiHoeSilver
Away!
Chicago
So i will buy 2 new tires with same tread on 20s n put back n check if it works fine .looks like the tire hieght on rear wheels 20 was little high then front i will be matching with front samd tread n height .anything else iam suppose to do after changes.
Screenshot_20170311-131325.png Screenshot_20170311-131341.png Screenshot_20170311-131352.png
Here is the difference between your 17s and your 20s. Not enough to warrant calibration IMO.
Sunny
Sunny
alright guys stock tire size is 265/55r17 and 20s 275/55r20 so 265 / 275 matter or its ok . or shld I stick with 275/55r20 with same tread all 4 ?
PG01
Up here to the right
As @HiHoeSilver said and the charts he posted on here.... as long as all 4 match. It doesn't matter if u put the 20s or 17s on. Tahoes came stock with both setups, maybe not exact tires sizes that you have but 17s or 20s were factory rims. If All 4 tires are the same ur good to go.
golavaman
