changing wheels need suggestion
HiHoeSilver
Away!
Chicago
yes ur right 2 different size effected the transfercase so putting back same fixed the noise , I will try again with 20s same thread .
now question is do I require any calibration ??
Calibrate what? What size tires are on the current 17s? What size tires are on the 20s?
HiHoeSilver
Away!
Chicago
Just sayin, thats what im trying to find out, BRO...we dont know and obviously he is asking about his speedo....
I understand we are both asking the same thing. I just thought different words from a couple voices might help the op understand what we're getting at. For all we know the OD of the tires on the 20s are indentical to that of tires on the 17s.
Sunny
Sunny
Thats what im asking.....dont think anybody is saying thing about diff rim sizes, op asked about calibration if he swaps to his 20s....."with same tread"
same size rims here is tire size pics
Sunny
Sunny
Right now I have 17s stock rims and tires on truck , as I had to swap cuz 20s gave me problem in 4*4.
HiHoeSilver
Away!
Chicago
I can't imagine why those would cause a problem as long as you had all 4 on the truck. Did you put the 20s back on after the noise had completely gone away? In terms of needing to calibrate your Speedo, what tire size is on the 17s?
PG01
Up here to the right
Exactly what i said, put 20's back on and see what happens. And again what are the size of the tires on 17" rims.
Sunny
Sunny
So i will buy 2 new tires with same tread on 20s n put back n check if it works fine .looks like the tire hieght on rear wheels 20 was little high then front i will be matching with front samd tread n height .anything else iam suppose to do after changes.
coops924
