Anyone try these?
adventurenali92
Big Bear Lake, ca
Update: So the pair I ordered from touring tech seems to be holding up fine. But the little plug where the air line plugs in doesn't stay seated right. The little plastic clip holds it in just kind sits there and doesn't keep it plugged in tight. Looking for a permanent solution. Its zipped tied right now but it's still not secured. Any thoughts anyone?
usafdenalidrw
usafdenalidrw
You said zip ties didnt work? What about an epoxy on the fitting to hold the line on?
Sent from my Nexus 6 using Tapatalk
adventurenali92
Big Bear Lake, ca
If I epoxy it in than its permantely glued and if I have to replace the shock down the road than its just stuck there to the shock?
usafdenalidrw
usafdenalidrw
I was thinking depending on how much slack you had in the line, you could just trim off the little bit of the end of the line where the epoxy is, when to need to remove the line and replace the shock
usafdenalidrw
usafdenalidrw
Ordered the shocks i originally posted in the thread. They just arrived and probably will install tomorrow. I'll let everyone know how they turn out
York
So what do you think of those shocks? everything seem to be working as it should?
Merc1973
Maryland
Those are CHICOM Arnott Knock-offs. Avoid them. They are passive, NOT electronic.
