Power locks don't work
Dennis W Horvath
None of the power door lock switches work was wondering if there fused or just realys?
Big Mama
Virginia
Usually fuses. Are you saying they don't work from the remote or from the driver and passenger door switches?
Big Mama
Virginia
Really strange. If the remote works then the power is getting to them. It would be odd for both front switches to go bad at once. Do you have a tool to test the switch? If the fuses are ok, and the remote works it must be the switch. You might try getting just one to keep costs down
rockola1971
Indiana (formerly IL)
Or they are powered from a different source after the battery when using remote vs the door switches. I unfortunately do not have my manual with me. Its 75 miles away sitting in my Denali.
Big Mama
Virginia
Agreed with Cattivo. Those not only read current but can power the accessory while you test it. If I recall there's a relay between the fuse box and window switch that I think is located under the drivers side dash
ScottyBoy
Shreveport, La
The door switch is on a different fuse than the lock relays are. The remote will still activate the lock relays if the fuse for the switch is blown, since it's not powered by the same fuse as the door switch. Just find the fuse that's blown and you should be good to go.
Chevymec
