Denali vs Std Yukon Light Output
YukonXL04
The Riverboat
Arlington, TX
That's much better. Actually shows something. However look how much light is above the front end. That looks very blinding for oncoming drivers. Hows the width?
I understand the ease of just swapping bulbs, but why not just do a retrofit and be done?
I'm not trying to be rude, I reread my first post and saw it came off that way, I apologize.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Simple LED swap is all you need, UNLESS you really want to change the look and go with the depos.
These better?????
Fogs and lows
73958
This is the exact reason NOT to just throw LEDs or HIDs in a non HID/LED projector housing. If you look at my cut off line picture below, you can see how none of the light is blinding oncoming drivers. Every bit of light is being used on the road. In your picture, this is no cutoff. You are blinding oncoming traffic...
BigDaddy13440
Rome, NY
Actually, I'm NOT blinding traffic. I'm friends with a few cops locally, and they have said that my lighting is directed low enough so that the hot spot isn't in their eyes. Could be that I'm parked on a very slight grade here, it may seem worse than it actually is.
My previous pictures were out on an open highway, again, not as bad.
hi-tech redneck
Howdy Big D,
I like your lighting setup.
I read where you mention buying these lights from eBay.
Do you remember the seller and the lights part #?
You mind sharing?
Thanks
HtRn
him__chase
