Should I get 35 or 50watt hids for my fogs from the retrofit source?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Hid nothing more than 25w. Bulbs sit too close to the lens and anything higher run the risk of melting. Trs sells a led direct replacement fog light that's is way better than hid or led bulbs
bacin87
bacin87
San Francisco, Ca
bacin87
bacin87
San Francisco, Ca
I think I found them:
https://www.theretrofitsource.com/complete-housings/fog-lights/chevrolet-round-morimoto-xb-led.html
but they are only 1,200 lm raw the
https://www.hidnation.com/products/5202-led-conversion-kit
are 4000lm raw.
sumo
rhode island
No those are them. Pop out the old ones and pop these in. Plugs right in to oem harmess
bacin87
bacin87
San Francisco, Ca
How bright are they? they list as a 24% as bright as their matching LED head lights
(The Retrofit Source H11: MORIMOTO 2STROKE & MORIMOTO 2STROKE Anti Flicker
https://www.theretrofitsource.com/l...evrolet+Tahoe&preselect=&preselect_restrict=1
The Retrofit Source 9005: MORIMOTO 2STROKE & MORIMOTO 2STROKE Anti Flicker
https://www.theretrofitsource.com/led-lighting/led-bulbs/9005-morimoto-2stroke.html?carDisplay=2007+Chevrolet+Tahoe&preselect=&preselect_restrict=1 ) and only 30% as bright as the Hidnation 5202 LED CONVERSION KIT ( https://www.hidnation.com/products/5202-led-conversion-kit ) I want to get an good Idea. do you have an image of them installed on your truck possible with your hid headlights running?
sumo
rhode island
They are plenty bright. There other members who use them with night pics. My fogs however don't work well and that's because I have a Tbss bumper cover that blocks a lot of the light output
AppocAlexx
Darth Appocalexx
Abilene TX
iv always heard that 35W is the highest you want to go. Anything higher at any space between lens and projector will melt the housing.
Also hasn't everyone on here been going with 35W I didn't even know they make less than 35W and if they did would that even be bright enough for low beams?
01Konvict
Boats n Hoes
Raleigh/SML
The xb led fogs are the best option. I've had eBay leds like the 2 stroke ones from retrofit source. They sent the light up and down with each side of the led. Blinded a ton of people.
sumo
rhode island
Depends on quality of the company that makes it. I seen people use eBay 35w and still experienced melting fogs or discoloration
Joerob25
