New headlights installed.
Drl flash when unlock button is hit on the keyless remote.
Parking lights flash when you hit lock on the remote.
Might be different for denalis.
On my Denali, park lights flash with either lock or unlock and dome/ puddle lights stay on for an extended period when unlocking, and fade off in for 5 seconds when locking. I can change this in the secondary DIC.
05Single
afraid of the dark
Oops my bad , yea sorry with chevy the drl doesn't flash buy stays on for a bit when the unlock button
MadDogDelpho
Texcellent
At the risk of sounding incompetent, what is the ping pong ball mod? Looking into getting some new headlights for the hoe, and while I can easily use the factory brackets, I'd like to see the options available.
chevrol8t
chevrol8t
Sorry just got off of work. Thanks for the helpful input. I will give all suggestions a try!
chevrol8t
chevrol8t
I'm pretty sure it's the marker (park) lights that flash, not the DRL's. Do your marker lights work? If not it might be polarity like mentioned before.
Yes my marker lights do indeed work.
chevrol8t
chevrol8t
I've never dealt with these lights but I would assume the drls do not need a resistor because that only fixes hyper flash and cruise. And leds don't draw enough power to blow a fuse.
:think:
I would check polarity, I bet all you need to do is reverse the plugs in the socket.
I will give it a shot! Thanks!
05Single
afraid of the dark
Just use your oem brackets, don't be ghetto like @Fosscore:Moon:
Fosscore
Just take a ping pong ball or two and wedge them in between the Depo headlights and their brackets. It helps stops the wobble as their brackets are a bit weak compared to the OEM brackets. I ran this for a while, then decided the change out the brackets between the Depos and OEM. The OEM brackets are much stiffer and of course fit the 2 pin holes much better.
:Good or Bad:@05Single when he is in Alaska vs. Vegas. On fiiiyyyeer. It is a bit ghetto yes, but it worked until I made the change...lol The Depos are great projectors, they just adjust a bit weird IMO, but the output for $100 is far superior, as mentioned to our OEM lights. Yes a proper retrofit would be a winner, but for me in the city, I am ok with what I have for the moment. lol @MadDogDelpho
05Single
afraid of the dark
Yea I know the ping pong mod has worked for many people for many years. If you don't have oem brackets to spare it works perfectly.
Yea @Fosscore I get back to my old self when I'm aways from that frozen desert lol.
But to whoever figured out the mod it's actually pretty genius.
Fosscore
Yes it is a cool simple mod and nobody would ever know. The Depo brackets are just flimsy and some guys have no issues. Mine wobbled and the adjustment was a little challenging, but nobody had been flashing me for being all goofy aligned.
:win:
Maybe that's cause I'm a bit lower than most trucks around me...:hmmm2:
Richard A
