Change Factory Radio and Keep Rear DVD 04 XL Denali
homerandpooh
I just purchased an 04 Denali XL and was hoping to change the dash unit while maintaining the rear dvd system. Possible? Are they connected or independent? I'm changing the radio to get BT, MP3 and a backup cam.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
IF your OE radio was the source of activating RSE (by hitting the source button) you can use this harness. If activation was somewhere else like the rear controls, then no you can't
Meta GMOS-014 - GM Onstar/ RSE/ and retain the warning chimes module
The GMOS-014 is designed to retain Onstar/ Rear seat entertainment (RSE)/ and retain the warning chimes that are normally lost when the OEM radio is removed. It also provides a 12 volt accessory output for aftermarket radio operation.
The GMOS-014 provides a mute/ parking brake/ vss or speed sense and reverse output to make installing an aftermarket navigation radio simpler and less time consuming.
H
homerandpooh
Great, I install this in conjunction with the aftermarket radio and I'm set. Thanks!
levilarsen
It's completely possible with the right radio, I have a Kenwood ddx and I just ran the wires for audio from the DVD player to the RCA wires on the stereo. it's made for that or an auxiliary cord but sense I don't use aux often I just hooked up my DVD player
Sent from my VS995 using Tapatalk
