yes it is possible, but to get the moldings on there are metal brackets under them that require 1/4'' rivets to install, there are 10 on each side. you have to drill holes in your rocker panels and install the rivets which are huge, I had to replace mine so I was lucky to already have the holes there. I wouldnt feel right drilling all those bigg ass holes. The steps require the brackets to be riveted on with those molding brackets as well. If you get a BIG double armed rivet gun (the handles are like a bolt cutter) you can do it yourself, I bought mine at harbor freight since I only needed to use that big of a rivet this one time only.
