Who’s replaced their drivers seat foam cushion?
Denaliz
Denaliz
Frisco,TX
You can order directly thru gm parts direct and other oem gm parts sites for the specific year model seat. I wouldn’t trust some random EBay seller unless they are a gm/oem parts EBay store.
Denaliz
Denaliz
Frisco,TX
I just ordered an oem one, new gm part # 25789849 from eBay after confirming it was an actual oem gm product and not aftermarket.
97.53 total
(If the seller lied, EBay will allow me to return at no cost but I’m not expecting an issue.)
chadw
I went with Seat Shop's durafoam when I replaced the driver's seat lower upholstery, and kind of wish I had gone with the OEM foam instead. The durafoam is more firm and, at least in my mind, not as comfortable as the OEM. That said, it works fine and after a while I have gotten used to it.
I dont know who told you steam "isnt a long term fix".. it is, its just a part of the fix, not the whole fix. You could cut out and replace only the bad foam if you wanted, but oem will cost about the same, and is easier.
Denaliz
Denaliz
Frisco,TX
97 dollars later- oem replacement foam cushion. Now I just need my pool build finished so I can use my garage again to install
BSarteSr
Read through this thread, I need to replace the driver side bottom foam on my '07 Yukon XL Denali, the cover is not bad but could be replaced at the same time.
Checking around on prices for both, found an OEM original GM on eBay for $120 shipped (less than the GM place when you add in shipping). The GM place is $92 but then add in shipping ($50) so more than the one on eBay.
The cover from the Seat Shop is $219, GM place is $203, both of those does not include the shipping cost. Found a replacement (non GM) on eBay for $43 but hesitate because I have been burned by electrical parts non-GM but then again this is not the same.
Any opinions or comments?
Denaliz
Denaliz
Frisco,TX
Go with the seat shop- the leather and quality is oem if not better.
89Suburban
Bull in the china shop
SE PA
I'm actually getting ready to replace my seat foam right now. I ordered it from the seat shop through Amazon. My problem is trying to find a cloth seat cover for it. I don't have leather and don't want it.
Jmily8474
