2 days ago, I noticed a loud whine while under load at 70mph @2200rpm. If I let off the gas, it quiets down.
I may have also had a slip in my transmission... Very minor.
It sounds like it is coming from the front... But that is just a guess (last week I had a dragging caliper, that we thought was in the front and it was actually in the rear). I checked front diff fluid, trans fluid,...will check the belts and pulleys.
I leaning towards the transmission... But should I look somewhere elsefirst?
Also, this is a new to me Suburban, I've put on 10-15k miles... It has about 170k mikes and I don't know what has been done with the transmission (but the fluid looks ok).
Would it be worth doing a fluid change, drop the pan and filter change? I was planning on getting to this in the spring.
