Hi everyone,
Looking at picking up a set of Fuel Off-Road wheels in a 20X9. What sort of backspacing and offset should I be running. The plan is to run a 275/55/20 A/T tire. I was going to crank the bars and add a 2 inch block in the back. For now I think I am going to leave it stock as I'm hoping to pick up a used 6 inch lift kit from another member on here. This won't be installed till spring so its important that I can use the wheels and tires now but they will still work and look good when the pro-comp kit is installed. Thank you for everyone's help, this site has been a great resource.
Cheers,
Cheers,
