Which jounce stops?
Bonestock
Currently just leveled with RC Keys and Bilstein 5100 running stock 285/65R18 Duratracs. When these are done in about 20-25k (4 months) more miles Ill be going with either Duratracks again or Falken Wildpeak. Either tire the size with me 275/70R18. Puts is roughly at 33.5 inch tall tires with is what I want.
Currently have all moog ball joints, control arms, inner and outer tie rods, pitman arm, steering gear, idler arm, idler arm bracket. Basically all new front suspension pieces EXCEPT the jounce stops. I simply dont know which ones to get. I was considering lifting 1 inch in the rear with spacers and cranking the keys a bit more to level it again.
Anyway which jounce stops do I need to get. I find plenty for 2500 trucks but Im not sure theyd work on my half ton.
BigDaddy13440
Rome, NY
I got the aftermarket ones from Energy Suspension off Amazon, something like $14 shipped. Drilled a hole through the pad on the lower control arm, and bolted them in, after hitting them with a belt sander to create a better angle of contact.
go4ahike
I went with stock jounce stop replacement, energy suspension spacerAD340736-1B70-4089-B648-22710D26A8E4.jpegF77D3120-BD1D-4BDE-8FD9-081B138E2941.jpeg
06JET
Wisconsin
So are they supposed to touch at normal ride height? So if you raise it with keys you need to add the spacer?
iasylum
