Voltmeter reading
ukrkoz
Auburn WA
Driving to work yesterday am, towards the last about 15 min of driving, noticed, that V meter needle dropped below 14. Connected Torque and is showed current oscillating between 12.7-13V.
OK, so panicking a bit, connect Torque on the way home - voltage sits at 14.7-15 across the entire commute, that being around 25-30 min. Gauge also shows as it should - above 14.
Is this about right, or I should just replace alternator? Or, it's voltage regulator acting up? Presuming, battery got charged, will voltage drop down not to overcharge it?
Multnomah Falls
I see no problem. Different voltage uses and voltage loads at different times. I saw this same info at my dash gauge and was concerned but testing showed what was going on and have never had a problem.
U
ukrkoz
Auburn WA
Oh, great. Had and still have real bad pass, start blowing on cold, as the result. I figured, it should drop voltage when there is no request for it, but what do I know..
Thank you
Multnomah Falls
Thank you
So, you had another problem/concern at the same time that you were concerned about readings? More "concise" details about this concern.
t_bergman
When was the battery last replaced? All of the GMT900s came with variable voltage control which controls output based on the load. If the battery is older I've personally had it reflected in the voltage meter as a low output as it's attempting to charge the batter but the battery isn't taking the power.
t_bergman
Battery is about 2 yo. On the plus side.
You may want to have it tested at a local auto parts store if close. I doubt WA has the cold we experience in WI/IL in the winter but I try to keep the batteries changed every 2 years as it's pain when they decide to quit.
I maintain (fiancé's ride) a 2018 Wrangler which decided to stop unlocking certain doors with a FCA branded battery at only 18 months old.
Fubar0715
Scott
Southern New Hampshire
I notice my volt gauge will fluctuate a bit, depending on how loud my radio is, which I can only assume is the 2500 watt amp is pulling a bit more power. Have the battery checked but could have been an onboard system pulling more power at the time when you looked down at the gauge..
BAMAUSAF
