Very loose front end...
Ever since I bought my 05 Yukon about 2 months ago I've had this horrible vibration in the front end at around 60-75 miles per hour. I complained to the dealer I bought it off of and they "supposedly" aligned it and balanced all 4 tires which did nothing. Yesterday I raised the front end and wiggled the front wheels left and right and there was a lot of movement from BOTH sides. The truck also pulls to the left and in order to keep it straight the steering wheel has to be at 2 o'clock. The vibration comes through the steering wheel too. Where should I look first??
mharders
Just outside of Seattle
Look at the inner/outer tie rods and work your way through your steering components (idler/pitman arm, steering box, ect)
Sent from my SAMSUNG-SM-N900A using Tapatalk
jdpber
GOLD MEMBER
The America
You state the wheels have lots of movement when jacked up that movement is bad wheel bearings. These trucks it is an entire hub assembly that contains new speed sensor. The entire assembly bolts to the spindle. This is what sounds like is your issue. $50-120 each depending on brand and store purchased. It's a fairly easy job. About 30-45 a side for the driveway warrior.
tekkitan
Could be inner/outer tie-rod and/or idler arm as stated. Wheel bearing will usually also allow you to wiggle the wheel top/bottom as well. If it is only left/right, I'd check the above.
tgui
OP, if you do the full assembly, get a 10lb slide hammer. It really helped me.
bl74
