01SLE
- Joined
- Mar 22, 2014
- Posts
- 71
- Reaction score
- 18
About 18 months ago i did a little suspension and steering overhaul on my 01 4x4 at 186k. It hasn't been maintained at all and needed a few things addressed so i just took care of everything.
Parts replaced in front were inner/outer tie rods, p arm, idler arm/mount, steering gear, upper/ lower c arm bushings and ball joints, axels, shocks, and brake components.
Rear parts were brake components.
I put new tires on all 4 corners and still ended up with a slight vibration above 55mph and some mild steering issues like bump steer and wandering at highway speeds. Had two alignments done and had the tires rebalanced on a Hunter Roadforce machine. Final and only answer i got was the no name tires i put on it were low quality and probably the cause of my vibration and crappy handling.
I put cheap tires on with the intent to sell the 22s and put a regular sized combo on. Never got around to it and got tired of working on it, bought a brand new Yukon SLT 4x4 and turned this '01 into my daily driver/ beater to keep miles off the'16.
So 35k miles later the junk tires are shot but the right front and rear are warn much much more than the left side. Tires were rotated a couple times but they're directional so only front to back, not corner to corner.
I'm now going to turn this truck into a mildly lifted Overland type vehicle but need to address this tire wear issue before i put $1,000 in 33x12.50s on it.
I'm out if ideas on the vibration, handling because i replaced everything and have no clue why tires would wear heavily on front and back right side only after two alignments on a new rack with competent techs. I even watched them do the alignment.
