Martinjmpr
Recently I've noticed an odd issue that pops up intermittently on my Suburban.
First, the basic info: 2004 Suburban 1500, 4x4, LT package, 5.3, 155,000 miles. I've owned it for about 15 months.
What will happen is this: Sometimes when I'm stopped at a stoplight waiting to turn left, I'll put the left turn signal on and instead of flashing, the turn signal will just stay on, steady. This ONLY happens while my foot is on the brake, as soon as I let off the brake the signal starts flashing again.
This seems to happen mostly when I first start out and everything is cold. By the time the truck warms up, it usually stops.
Now I know a blown bulb will cause the light to flash rapidly (double speed) but what would cause the turn signal to not flash at all? Only thing I can think of is either the flasher unit or something to do with the brake light switch (since it only happens when the brakes pedal is depressed.)
Anyone else have this issue? Also, where is the flasher unit located? Is it on the fuse panel at the end of the dashboard or under the dashboard?
Thanks in advance!
Thanks in advance!
